NAV Menu Reference Properties
Last Post 2007-05-24 04:41 PM by Jos Driessens. 5 Replies.
FredUser is Offline
2007-05-22 06:21 PM
I'm a C# developer, new to DotNetNuke and I really love what I see.  I'd like to use DNN for several of my customer sites even if it means re-training myself in VB.NET.  The DNNCreative site has been invaluable in helping me to get up to speed on how to use DNN.  I'm currently using DNN 4.5.1 which uses the new NAV menu.  Some of my clients require a vertical menu, but the included vertical menu skins that come with DNN 4.5.1 are a tree view and look rather "toyish".  Documentation on how to use the new NAV menu has been hard for me to find.  I "think" the NAV menu has a vertical option, but I'm unclear as to what other options it has and how to use them.
Can you recommend any sites, example code, documentation or, in essence, a good road map for learning about NAV and its capabilities?  I understand basic CSS and javascript, but I'm not an expert in those areas.
Many thanks.
Jos DriessensUser is Offline
2007-05-23 09:52 AM
A good start is http://webcontrols.dotnetnuke.com
Regards
Jos
2007-05-23 10:08 AM
There was a post here by AGM where they listed the various properties, but it appears as though the properties have now been removed so I'm pasting them in here for future reference:
I haven't had chance to delve into the NAV menu yet, but I will do at some point and if I have any success I will put the info in the skinning toolkit. - If you find any other sources of info add it in here as it will make it easier for me to research the NAV menu later on.
From the list below, it looks as though you need to look at the Rendering properties - ForceDownLevel, Control Orientation
NavigationProvider
Description
Paths
PathImage
Directory to find the icons
PathSystemImage
Directory to find the images necessary for the control (i.e. spacer.gif)
PathSystemScript
Directory to find associated script files for the control
Rendering
ForceDownLevel
Flag to force the downlevel menu to display (values: true, false)
ForceCrawlerDisplay
Displays the full menu as an indented list of normal hyperlinks (like a sitemap) {true|false}
ControlOrientation
Determines how the menu is displayed, horizontal or vertical (values: vertical, horizontal)
ControlAlignment
Alignment of the menu within the menu bar. {Left|Center|Right|Justify}
Mouse Properties
MouseOutHideDelay
Number of milliseconds to wait until menu is hidden on mouse out. (0 = disable)
MouseOverDisplay
Adjusts effect when mouse moves over menu bar item (Values: Outset, Highlight, None)
MouseOverAction
Makes menu expand on mouse over (unlike any menu found within the Windows environment)(Values: true, false)
Indicate Children
IndicateChildren
use arrows to indicate child submenus
IndicateChildImageSub
IndicateChildImage
IndicateChildImageExpandedSub
Image to use on sub node when children expanded
IndicateChildImageExpandedRoot
Image to use on root node when children expanded
Custom HTML
NodeLeftHTMLRoot
HTML text added to the beginning of the Root menu items
NodeRightHTMLRoot
HTML text added to the end of the Root menu items
NodeLeftHTMLSub
HTML text added to the beginning of the sub menu items
NodeRightHTMLSub
HTML text added to the end of the sub menu items
NodeLeftHTMLBreadCrumbSub
HTML to display to the left of the node that resides in a submenu and is a breadcrumb
NodeLeftHTMLBreadCrumbRoot
HTML to display to the left of the node that resides in the root and is a breadcrumb
NodeRightHTMLBreadCrumbSub
HTML to display to the right of the node that resides in a submenu and is a breadcrumb
NodeRightHTMLBreadCrumbRoot
HTML to display to the right of the node that resides in the root and is a breadcrumb
SeparatorHTML
The separator between Root level menu items. This can include custom skin images, text, and HTML (ie. <!--[CDATA[  ]]--> )
SeparatorLeftHTML
The separator used just before a root level menu item. A use for this might be a left edge of a tab image for example
SeparatorRightHTML
The separator used just after a root level menu item. A use for this might be a right edge of a tab image for example
SeparatorLeftHTMLActive
The separator used just before an active root level menu item
SeparatorRightHTMLActive
SeparatorLeftHTMLBreadCrumb
The separator used just before a root level menu item found in the breadcrumb array list
SeparatorRightHTMLBreadCrumb
CSS
CSSControl
Menu Bar CSS Class
CSSContainerRoot
Menu Container CSS Class
CSSContainerSub
SubMenu CSS Class
CSSBreak
Menu Break CSS Class
CSSIndicateChildSub
Menu Arrow CSS Class
CSSIndicateChildRoot
Menu Root Arrow CSS Class
CSSNode
Menu Item CSS Class - ALL Nodes
CSSNodeRoot
CSS Class used for root menu items - Overrides CSSNode
CSSBreadCrumbSub
CSS Class used for sub menu items when they are found in the breadcrumb array list - Overrides CSSNode
CSSBreadCrumbRoot
CSS Class used for root menu items when they are found in the breadcrumb array list - Overrides CSSNode
CSSNodeSelectedRoot
CSS Class used for root menu items when they are the active tab - Overrides CSSNode, CSSBreadCrumbRoot
CSSNodeSelectedSub
CSS Class used for sub menu items when they are the active tab - Overrides CSSNode, CSSBreadCrumbRoot
CSSNodeHover
Menu Item CSS Class for mouse-over - ALL Nodes
CSSNodeHoverSub
CSS Class used for sub menu items when they moused-over - Overrides CSSNodeHover
CSSNodeHoverRoot
CSS Class used for root menu items when they moused-over - Overrides CSSNodeHover
CSSSeparator
CSS class used for the root level menu item separator
CSSLeftSeparator
CSS class used for leftseparator
CSSRightSeparator
CSSLeftSeparatorSelection
CSS class used for leftseparatoractive
CSSRightSeparatorSelection
CSS class used for rightseparatoractive
CSSLeftSeparatorBreadCrumb
CSS class used for leftseparatorbreadcrumb
CSSRightSeparatorBreadCrumb
CSS class used for rightseparatorbreadcrumb
CSSIcon
Menu Icon CSS Class
Styles
StyleBackColor
Background color
StyleForeColor
Fore color of menu item when selected
StyleHighlightColor
Color of top and left border to give a highlight effect
StyleIconBackColor
Background color in area where icon is displayed
StyleSelectionBorderColor
Color of border surrounding selected menu item
StyleSelectionColor
Background color of menu item when selected
StyleSelectionForeColor
StyleControlHeight
Menu bar height in pixels
StyleBorderWidth
Menu border width in pixels
StyleNodeHeight
Menu item height in pixels
StyleIconWidth
Width of icon column in pixels
StyleFontNames
Fonts to use
StyleFontSize
Font Size Style
StyleFontBold
Font Bold Style
Animation
EffectsShadowColor
Color of the shadow
EffectsTransition
Determines which transition to display
EffectsDuration
Number of seconds the transition will take
EffectsShadowDirection
Determines which direction the shadow will fall
EffectsShadowStrength
Determines how opaque the shadow is
EffectsStyle
IE only property for SubMenu styles and transitions
FredUser is Offline
2007-05-23 11:07 PM
Thanks Lee, I'll post anything I find.
2007-05-24 01:51 PM
Lee,
imho your list does not correspond with the documentation. The Styles and Animation only apply to the SolPartMenu but not to the DnnMenuNavigationProvider, as are many other settings. I am using the [NAV] menu, but I am still trying to figure out how it works.
2007-05-24 04:41 PM
Forget my previous post. It looks like there are much more functions available than documented.
