Glorified List Serve
Last Post 2007-03-30 06:28 PM by richardhobbs. 3 Replies.
Jeff WintersUser is Offline
2006-03-08 01:59 PM
Hi All,
I'm moving a new client from static html to DNN.
They have an 'old' listserver. I want to replace it with a better solution.
Is there something that can...
1) Allow one administrator to post information in a dnn module.
2) All 800 members of the organization will be notified of the post by email. (Assuming I have all users registered of course)
B
2006-03-08 02:23 PM
1) I don't know how experienced you are with DNN. - Do you know about the security roles that you can setup to give access to certain users. - You could set this up and then just give access to that particular user so that they can edit the info in a dnn module. - Is this what you mean?
2) If you import all of the users into your DNN installation you can use the built in Newsletter module to send an email to all of the registered users. - But, however, beware that I discovered that once the user list went beyond 500 users, the module failed to send all of the emails. - There is a module you can buy from DNN modules: http://www.dnn-modules.com/Default....x?tabid=38
which is more reliable than the Newsletter module, I have used the Email Manager module, but I haven't tested it on a large number of emails.
The current method I use for sending emails is to use a web service from http://www.constantcontact.com" target="_blank">Constant Contact
as this is a much more reliable method and pretty much guarantees your emails will be delivered. I extract the registered users on the DNN site using a query in Enterprise Manager and transfer the results of the query into an excel file, I then upload the excel file to constant contact.
The downside to Constant Contact is that it is not a simple process that you can pass onto your client. - The easier method for your client will be to use the Email Manager module.
Hope this helps, thanks,
2006-03-08 02:33 PM
Many Thanks!
Great food for thought. I will investigate the Newsletter and Email Manager options.
I will come back with my findings so others can share.
Thanks again,
B
richardhobbsUser is Offline
2007-03-30 06:28 PM
I'm looking for someone to do this very thing.
Have you had any success?
The new active forums has a mail connector that acts similar to a listserver.
Wondered what you did to get your site up and running.
I have six hundred members on my listserver.
I need help figuring out how to transistion this site into DNN better
