custom FCK editor
Last Post 2007-04-10 04:33 PM by Lee Sykes. 1 Replies.
David ThomsonUser is Offline
2007-04-05 10:10 AM
Does anybody know how to remove all the inline style buttons from the fck editor so that I can end up with something like this text editor for the forums. I'm not even sure where I should be looking for information.
2007-04-10 04:33 PM
Click on 'show custom editor options' underneath the text box
Editor toolbar view options allows you to specify which roles are allowed to view elements of the toolbar
Click on the edit pencil icon for each toolbar element and select which roles are allowed to view that toolbar section
Scroll down: apply customs settings to: select instance, module, or portal depending on whether you wish to apply the view settings just to this instance of the module, or to the module across the entire portal or for all modules in your portal.
