FCKEditor & Overriding default html editor
Last Post 2007-03-27 09:32 AM by Lee Sykes. 3 Replies.
paul.thomsonUser is Offline
2007-03-27 03:26 AM
Hi Guys, I just used the FCKEditor tutorial to install and use FCKEditor on our DNN site. We want to use the default html editor as the default and only the FCKEditor in certain circumstances. To add the FCKEditor control at the page level would i : 1) - Register a tag prefix for the dll <%@ Register TagPrefix="FCKeditorV2" Namespace="FredCK.FCKeditorV2" Assembly="FredCK.FCKeditorV2" %> 2) - Use the control as follows <FCKeditorV2:FCKeditor id="FCKeditor1" BasePath="~/FCKeditor/" runat="server" /> NOTE: That the default code that was present when the FCKEditor was enabled within web.config as the default editor is obviously, no longer in use. I am currently getting this error: Error: Edit ArticleList is currently unavailable. DotNetNuke.Services.Exceptions.ModuleLoadException: C:\paul\10386 Battlefront\Website\DesktopModules\FourthMedia.Articles\EditArticleList.ascx.vb(133): error BC30451: Name 'txtSummary' is not declared. ---> System.Web.HttpCompileException: C:\paul\10386 Battlefront\Website\DesktopModules\FourthMedia.Articles\EditArticleList.ascx.vb(133): error BC30451: Name 'txtSummary' is not declared. at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at System.Web.UI.TemplateControl.LoadControl(String virtualPath) at DotNetNuke.UI.Skins.Skin.InjectModule(Control objPane, ModuleInfo objModule, PortalSettings PortalSettings) --- End of inner exception stack trace --- Any help would be greatly appreciated guys Thanks again, Paul
2007-03-27 03:29 AM
(sorry about the formatting) ---- > Hi Guys, I just used the FCKEditor tutorial to install and use FCKEditor on our DNN site. We want to use the default html editor as the default and only the FCKEditor in certain circumstances.
2) - Use the control as follows NOTE: That the default code that was present when the FCKEditor was enabled within web.config as the default editor is obviously, no longer in use.
2007-03-27 04:09 AM
Hi Guys,
I'm back 'haha' and was able to resolve the above error. Currently i'm not sure whether i need to add a file to the controls folder such as FCKEditor and then register it like : <%@ Register TagPrefix="dnn" TagName="TextEditor" Src="~/controls/FCKEditor.ascx"%>
or should i follow the wiki manual : http://wiki.fckeditor.net/Developer...on/ASP.Net
and use the register line : <%@ Register TagPrefix="FCKeditorV2" Namespace="FredCK.FCKeditorV2" Assembly="FredCK.FCKeditorV2" %> and control line :
<FCKeditorV2:FCKeditor id="FCKeditor2" BasePath="~\Providers\HtmlEditorProviders\Ftb3HtmlEditorProvider\" runat="server" />
I assume that i can get away with the second option as it has been stated in the manual but now think that i have the paths or something wrong ?
Thanks in advance,
Paul
2007-03-27 09:32 AM
I'm not sure what the best way to implement this would be. - Your best bet would be to ask the FCKEditor core project team in the dotnetnuke forum.
