_______________START OF ERROR MESSAGE____________________ Configuration Error Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately. Parser Error Message: The code subdirectory '/home/App_Code/ICPC-Counter/' does not exist. Source Error: Line 189: </expressionBuilders> Line 190: <codeSubDirectories> Line 191: <add directoryName="ICPC-Counter" /> Line 192: <add directoryName="IFrame" /> Line 193: <add directoryName="Links" /> Source File: C:\WEBS\DotNetNuke\web.config Line: 191 __________________ END OF ERROR MESSAGE___________________ * The physical path on the drive is c:\Webs\Dotnetnuke\App_Code\ICPC-COUNTER The problem I am having is this: I CAN NOT edit or even select setting on any module on any home page of any portal on the server. I CAN however edit anything on any subpages. I have removed the lines from the web config, reinstalled the three modules, same result. I have also removed the lines and tried to edit or select settings on a module and get: _______________START ERROR MESSAGE________________________ Server Error in '/home' Application. -------------------------------------------------------------------------------- Could not load file or assembly 'DotNetNuke.HttpModules' or one of its dependencies. The system cannot find the file specified. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.IO.FileNotFoundException: Could not load file or assembly 'DotNetNuke.HttpModules' or one of its dependencies. The system cannot find the file specified. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Assembly Load Trace: The following information can be helpful to determine why the assembly 'DotNetNuke.HttpModules' could not be loaded. WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. Stack Trace: [FileNotFoundException: Could not load file or assembly 'DotNetNuke.HttpModules' or one of its dependencies. The system cannot find the file specified.] System.RuntimeTypeHandle.GetTypeByName(String name, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMarkHandle stackMark, IntPtr pPrivHostBinder, Boolean loadTypeFromPartialName, ObjectHandleOnStack type) +0 System.RuntimeTypeHandle.GetTypeByName(String name, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean loadTypeFromPartialName) +153 System.Type.GetType(String typeName, Boolean throwOnError, Boolean ignoreCase) +63 System.Web.Compilation.BuildManager.GetType(String typeName, Boolean throwOnError, Boolean ignoreCase) +124 System.Web.Configuration.ConfigUtil.GetType(String typeName, String propertyName, ConfigurationElement configElement, XmlNode node, Boolean checkAptcaBit, Boolean ignoreCase) +76 [ConfigurationErrorsException: Could not load file or assembly 'DotNetNuke.HttpModules' or one of its dependencies. The system cannot find the file specified.] System.Web.Configuration.ConfigUtil.GetType(String typeName, String propertyName, ConfigurationElement configElement, XmlNode node, Boolean checkAptcaBit, Boolean ignoreCase) +12773840 System.Web.Configuration.Common.ModulesEntry.SecureGetType(String typeName, String propertyName, ConfigurationElement configElement) +69 System.Web.Configuration.Common.ModulesEntry..ctor(String name, String typeName, String propertyName, ConfigurationElement configElement) +66 System.Web.HttpApplication.BuildIntegratedModuleCollection(List`1 moduleList) +300 System.Web.HttpApplication.GetModuleCollection(IntPtr appContext) +1262 System.Web.HttpApplication.RegisterEventSubscriptionsWithIIS(IntPtr appContext, HttpContext context, MethodInfo[] handlers) +133 System.Web.HttpApplication.InitSpecial(HttpApplicationState state, MethodInfo[] handlers, IntPtr appContext, HttpContext context) +304 System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +404 System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +475 [HttpException (0x80004005): Could not load file or assembly 'DotNetNuke.HttpModules' or one of its dependencies. The system cannot find the file specified.] System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +12966756 System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +159 System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +12806561 -------------------------------------------------------------------------------- Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.18408 ___________________END OF ERROR MESSAGE_______________________________________________________ ** The File DotNetNuke.HttpModules.DLL is current, unblocked and in the right place. Any thoughts????? This happened after I MOVED the installation from production to live and did the 7.2.0 upgrade. Not sure at which point things got messed up. Dale Graham
