Lee Sykes DNN Creative Staff
 Nuke Master VI Posts:4945
| 2005-09-12 09:33 AM |
http://forums.asp.net/958251/ShowPost.aspx
They also supply Virtual Dedicated Servers and Dedicated Servers
<!--Table Header-->
| Choose your hosting plan! | <!--Hosting Plan Names-->
 | <!--Hosting Plan Prices-->
| Monthly Fee | <!--Economy Plan Price-->
$3.95 | <!--Deluxe Plan Price-->
$9.95 | <!--Premium Plan Price-->
$19.95 | <!--Disk Space-->
| Disk Space |
500 MB |
2,000 MB |
4,000 MB | <!--Data Transfer-->
| Monthly Data Transfer |
25,000 MB (25 GB) |
100,000 MB (100 GB) |
200,000 MB (200 GB) | <!--Email Accounts -->
Email Accounts Includes spam, fraud, & virus protection; Webmail; Catch-all; 10 MB space; and more! |
100 |
500 |
1000 | <!--Email Aliases -->
| Email Forwarding Accounts |
50 |
Unlimited |
Unlimited | <!--turbo ssl -->
SSL Certificate -- a $29.95 value! |
Included | <!--Databases -->
Databases (New!) Each database can include multiple tables |
1 MySQL |
10 MySQL MS Access (Windows) SQL Server 20001 (Windows) |
25 MySQL MS Access (Windows) SQL Server 20001 (Windows) | <!--Operating Systems -->
Server Operating System
Select Windows or Linux:
| <!--Scripting Languages -->
| Languages Supported |
Windows: ASP Linux: PHP |
Windows: ASP/PHP Windows: ASP.NET Linux: PHP/Perl/Java |
Windows: ASP/PHP Windows: ASP.NET Linux: PHP/Perl/Java | <!--Forums -->
| Forums (NEW!) |
Included |
Included | <!--Blogging -->
| Blogging (NEW!) |
Included |
Included | <!--Photo -->
| Photo Galleries (NEW!) |
Included |
Included | <!--Free Scripts -->
Free Software/Scripts Chat, Content Management, Image Galleries and More |
Free Windows Items Free Linux Items |
Free Windows Items Free Linux Items | <!--Google AdWords -->
FREE! $25 Google AdWords credit |
FREE! $25 Google AdWords credit | <!--Select a Plan -->
Select a Plan Buy 12 months and Save 20%! |
Just $3.95/mo!
Just $9.95/mo!
Just $19.95/mo!
M R
 Nuke Newbie Posts:8
| 2006-05-26 03:13 AM |
GoDaddy is a great hosting provider. However, not the best for DNN. With their shared hosting packages you are not able to install DNN into your root folder due to folder permission related to security. You must create a virtual directory first, therefore you if you intended to use your DNN app as your home page a redirect is required unless you dont mind the URL with the trailing folder. They do offer DNN as a "value applicatoin" with their hosting packages and can be installed from their control panel. Also, I believe that if you used the value application install option, the virtual directory that is created by default is not accessable via FTP preventing you from accessing the DNN app files. I believe that you can avoid all of this hassle, cough up the cash and pay for a dedicated hosting package allowing you full control over the hosting server.
abhishek kant
 Nuke Newbie Posts:1
| 2006-07-13 07:45 PM |
i have had a dedicated server plan with godaddy.com. i am not at all happy with them.
the site is extremely slow and it appears that their HDD has a problem. this was indicated by the perf counters reading 100% disk time all the time and disk queue length more than 2 all the time..
there is no one to assist you with diagnosing the problem and i had to spend countless hours figuring out what went wrong. now i have to switch HDD i think and they wouldn't even support me with backup.
bad experience.
regards
abhishek |
Jeeradate Kaowkanchana
 Nuker Posts:13
| 2007-04-14 02:20 PM |
I have 5 domain names for different purpose but Godaddy deluxe plan allow to install only 2 DNNs (2 SQL Database) then I try to use other 3 domain names with parent/child portal. When I point my domain name to the child portal directory "root/dotnetnuke/childPortal" (dotnetnuke is where in install DNN) and add http alias as www.mydomainname.com in DNN, DNN looking for App_Code directory in the child portal directory not in the DNN installed directory. That cause the error which cannot solve so far. Any idea or suggest would be appreciated. Best regards, Jeeradate K. |
 Nuker Posts:13
| 2007-04-17 08:49 AM |
Thank you very much for your advice. Godaddy support staff try very hard to solve this problem, I see from the Site log that they work very hard on this problem in my site for many hours. I had forward your advice to him. I will let you know the result as soon as it fixed.
 Nuker Posts:13
| 2007-04-17 03:55 PM |
It work, at last Mr. Sean R Smith at Godaddy support did it for me but I don't know how to do that, he is document the procedure for all the users. http://www.noklek.com . Now Godaddy's customers can host the domain name by parent portal of the DNN which install in sub directory. I think install DNN in the sub directory is good as you can install more than one DNN installation. Best regards, Jeeradate K. |
Adle
 Nuke Newbie Posts:8
| 2007-04-20 01:53 AM |
Don't forget that with those plans you have only MSSQL 2000 available on godaddy and if you developed your own modules which use procedure with new features from MSSQL 2005 - you screwed you need to have MSSQL 2005 and you realize godaddy is not for you.
 Nuker Posts:13
| 2007-04-20 01:56 PM |
For my deluxe plan, I have 2 SQL Database which quite limited. I use both of them to install 2 DNN installation. If I need to develop the module I will my home PC for module developing but so far I never develope any module. I love the Godaddy support. The time they spend on my case worth more than years of hosting fee. Godaddy is my first hosting company I have experience with. I can not say it is the best. But it is quite OK for me. |
ismet dumlupinar
 Nuke Active Member Posts:33
David Snow
 Nuke Master Posts:150
| 2007-05-15 10:31 PM |
I have used GoDaddy for 6 months for DNN and 5 years for web hosting. I am looking for another provider for several reasons:
- GoDaddy's unreasonable permissions on the root directory make installation and updating DNN a huge pain. In my case I installed in /dnn and moved the files up one level have the instal was completed. Basiclly at GoDaddy you have 3 DNN choices. 1. Use their value application and have little or no control. 2. Install in a subdirectory (/dnn) and not be vued as a "site" by Google & Yahoo or Use Redirects and loose referrer info. 3. Go thru hoops to to the install and upgrades to have your site at root.
- GoDaddy's email system keeps blacklisting IP blocks of people who send me mail, such as Border's Books. You don't hear about the blocked mail at all.
- GoDaddy's quality of support has dropped greatly during the 6 month
I will be evaluating / trying other ISPs during the next week or two and you may see my comments added for other ISPs
/DaveS |
andyb1979
 Nuke Pro Posts:63
| 2007-06-06 08:33 PM |
I will be evaluating GoDaddy soon, simply because of the amount of storage / bandwidth they offer. The deluxe plan now offers 100GB of storage and a 1TB of bandwidth / month for little over $6!
https://www.godaddy.com/gdshop/hosting/shared.asp?ci=9009
If they're rubbish I will post back info here in a few weeks.
Cheers, |
Sites I made thanks to DNNCreative vids! Rock Rhyme & Reason Fest | The Big Match | Calvary Stockport | Stephen Webster |
andyb1979
 Nuke Pro Posts:63
| 2007-06-06 08:55 PM |
Wait a sec:
"Don't forget that with those plans you have only MSSQL 2000 "
- what are the disadvantages of using SQL 2000? Quite a lot of hosting providers use this as far as I can see. Can someone point me to a host that provides SQL 2005?
Cheers |
David Snow
| 2007-06-06 09:06 PM |
Bet you a buck you can't get DNN installed in the root within a week at Godaddy  Lots of space is nice, but I just traded space for a DNN friendy provider, SQL Mgr access and pain-free backups and restores. BTW When I left GD all new databases were SQL 2005. /Dave |
ismet dumlupinar
| 2007-06-06 09:17 PM |
Well, i am not a reseller of Godaddy, but i strongly suggest them if you have small budget. I will update my Tutorials for DotNetNuke 4.5.3 installation to root. MSSQL 2005 is better, for performance and reliability. If you are rich, Discount ASP.NET is good choise, but they are expensive, support is cool. I'm poor, so i need to continue with Godaddy, as i understand how to fight with them, no problem at all. Once i learn new things about Godaddy, i am sharing my experince with my visitors ( http://www.mynetnuke.com for Global users) Regards. |
DNN Tips DotNetNuke Help for beginners |
andyb1979
 Nuke Pro Posts:63
| 2007-06-08 07:33 AM |
Ok, thanks for all your advice! The last thing I want is a rubbish host... Here's a quick background on my requirements: I represent a series of churches in the UK, and we are looking to upgrade our websites one by one to add audio / video content amongst other things. For instance, for one church we wish to host 60 audio messages (15MB / message) totalling 900MB, and add 1 audio and 1 video message per week, (60MB / week). As you can see, our storage requirements will quickly reach several GB. We wish to add podcasting capability per site, and are thinking of purchasing licences for NukeSyndicate. Now I doubt bandwidth will be that high. Its not YouTube, and the "audience" will be a small group of users. I was initially attracted to GoDaddy as they offered silly storage for a low price, however the more I hear about them the more Im thinking "stay away!"... We don't have a lot of money, and would like to do this as cheaply as possible, however Im sure we could afford a few hundred $USD / year, especially with the awesome 2:1 £GB exchange rate  So, baring the above in mind, does anyone have any advice as to how I may achieve this? I also have access to unlimited storage at fasthosts.co.uk, but no MSSQL. One idea I had was to host the DNN site(s) at the highly acclaimed IHostASP but have mass storage elsewhere, then develop a clever module that allows upload/download of content to the remote site thereby making this transparent to users / administrators. Cheers, AndyB1979
 Nuke Master VI Posts:9001
| 2007-06-08 02:11 PM |
Don't try to make things too complicated. Shop around and find one hosting company that can meet your DNN, storage and bandwidth requirements. If you deal with a host that actually knows DNN, that will be a great help if and when you have problems. |
Déclic Vidéo FX
 Nuke Pro Posts:91
