You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
DotNetNuke®
DotNetNuke® Questions
I am getting error when clicking on Host > Host Settings
Last Post 02/13/2012 11:18 PM by
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
vijendra
02/11/2012 2:47 AM
I am getting error when clicking on Host > Host Settings.
Pls let me know how to solve this. I am attaching the screenshot of the error.
Pls help me to resolve this problem.
Also copying the error below :
Source Error:
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
<%@ Page Language="C#" Debug="true" %>
or:
2) Add the following section to the configuration file of your application:
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.]
DotNetNuke.Modules.Admin.Host.HostSettingsModule.BindData() +5180
DotNetNuke.Modules.Admin.Host.HostSettingsModule.Page_Load(Object sender, EventArgs e) +112
[ModuleLoadException: Error: Host Settings is currently unavailable.]
DotNetNuke.Services.Exceptions.Exceptions.ProcessModuleLoadException(String FriendlyMessage, PortalModuleBase ctrlModule, Exception exc, Boolean DisplayErrorMessage) +409
DotNetNuke.Services.Exceptions.Exceptions.ProcessModuleLoadException(PortalModuleBase ctrlModule, Exception exc, Boolean DisplayErrorMessage) +85
DotNetNuke.Services.Exceptions.Exceptions.ProcessModuleLoadException(PortalModuleBase ctrlModule, Exception exc) +7
DotNetNuke.Modules.Admin.Host.HostSettingsModule.Page_Load(Object sender, EventArgs e) +134
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Control.LoadRecursive() +141
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
[PageLoadException: Error: Host Settings is currently unavailable.]
DotNetNuke.Services.Exceptions.Exceptions.ProcessPageLoadException(Exception exc, String URL) +324
DotNetNuke.Framework.PageBase.Page_Error(Object Source, EventArgs e) +379
System.Web.UI.TemplateControl.OnError(EventArgs e) +8693002
System.Web.UI.Page.HandleError(Exception e) +84
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +6776
System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +242
System.Web.UI.Page.ProcessRequest() +80
System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context) +21
System.Web.UI.Page.ProcessRequest(HttpContext context) +49
ASP.default_aspx.ProcessRequest(HttpContext context) +4
System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +181
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
DNN MVP
02/11/2012 11:44 PM
What version of DotNetNuke are you using?
Is this a new install, or is this an existing install? Did this work before? If so, what changes have you made.
You might want to make the suggested change to web.config and see what that error says.
Joe Craig,
Patapsco Research Group
Complete DNN Support
vijendra
02/13/2012 2:22 AM
The below error i am getting putting the Debug True
Could Not Load Skin: /Portals/_default/Skins/Instant Food/Instant-food.ascx Error: D:\WebRoot\Domains\instantfoods.com\wwwroot\Admin\Skins\banner.ascx(4): error BC30512: Option Strict On disallows implicit conversions from 'Object' to 'Integer'.
Pls let me know how to solve this pls. Pls help me to resolve the problem.
Is any file i can attach so that you can see and let me know the problem pls.
DNN MVP
02/13/2012 11:18 PM
Try making strict="false". That might make the error go away, yet still provide additional debugging information.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
DotNetNuke®
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
