iPhone website logo in DNN root directory
Last Post 2012-02-14 07:07 PM by JohnnieD. 5 Replies.
JohnnieDUser is Offline
2012-02-09 07:51 PM
I'm trying to put an iPhone logo that I made into my site so when someone saves the website on their iPhone home screen the custom logo I made will show up. According to two different sites that I read, the iPhone logo needs to be located in the main root directory of the website.I went to Admin> File manager> And then uploaded the iPhone logos to the Portal Root. Now when trying to put a shortcut on the home screen of the iPhone I don't get the logo that I uploaded to the root directory.
One article states that this can also be added to the header, but I'm not sure what the correct address or path would be so I could include it correctly in the header. I'll list the code below.
perhaps you want to use a different file name or format – you can use a link tag in the head of the document, such as:
iHelloWorld
The links to the two articles I'm reading are below:
http://www.bernskiold.com/2011/01/0...r-website/
http://vjarmy.com/archives/2008/01/howto_iphone_webclip_icons.php
If I want to include the code in the header, what would be the path to the root directory where the icons are?
2012-02-10 02:02 AM
I'm supposed to add this link to make my custom logo show up on iPhones.
< link rel="apple-touch-icon" href="/apple_touch_icon.png"/ >
Where in DNN would I add it? I put it in the header section of the main page and it doesn't show up when I save the page on my iPhone.
Where should I add this code?
Specifying a Webpage Icon for Web Clip
https://developer.apple.com/library/IOs/#documentation/AppleApplications/Reference/SafariWebContent/ConfiguringWebApplications/ConfiguringWebApplications.html
2012-02-12 05:12 AM
Try adding that to the header or footer of an HTML module make the module appear on every page.
Alternatively, you could make it part of the skin. Or, use Will Strhol's Inject module to place it in the page. I think that it needs to go in the body, not the header.
2012-02-13 04:47 PM
Posted By Joseph Craig on 2012-02-12 12:12 AM
I tried adding it to the header of the main page and also used Will Strhol's Inject Module. I didn't have any luck with either one. I placed the code in both the top and bottom of the inject module. My .png image is in the portal root like the above articles mentioned. I could be adding incorrect code. It doesn't include anything about the portal root. How should the code read?
2012-02-14 04:27 AM
Possibly you don't have the right path to the file?
What is the link in your page's source?
Something like http://mydomain.com/Portals/0/Images/file.png would be correct.
2012-02-14 07:07 PM
Posted By Joseph Craig on 2012-02-13 11:27 PM
I did what you suggested and it worked. I had the wrong path. I put "Portal" instead of Portals". The only thing I need to work on now is the Title that shows up for the icon. I'm hoping this can be fixed by adding 'title' to the code.
< head>
< title>iHelloWorld
< link rel="apple-touch-icon" href="/whatever.jpg"/ >
< /head >
RE: Deploying dnn by Sameer
Just sent it.
