Fixed size container
Last Post 2012-03-30 10:47 PM by Joseph Craig. 3 Replies.
Author Messages Not Resolved
Aggiedan97User is Offline
2012-02-09 07:20 PM
I am looking for advice or an actual container that has a fixed height (and width). An HTML module will need to scroll down for additional content.
I realize this may seem counter-intuitive, but this is the requirement.
Thoughts are greatly appreciated.
Joseph CraigUser is Online
2012-02-09 07:44 PM
Use an HTML module and style the container to have a fixed height and width. Set the overflow attribute to scroll.
2012-03-30 02:29 PM
In a Horizonal menu, it is possible to prevent the top-level menu from exposing child pages without un-checking the "include in menu" option of these sub-pages?
2012-03-30 10:47 PM
The short answer is yes.
The longer answer is that you will need to modify your skin file to set the attributes of the menu to display only the "root" level items. How you do this will depend on the menu that is used in the skin. We do have tutorials for the DNN NAV Menu and the DDR Menu.
Ask again if you need more.
RE: Deploying dnn by Sameer
Just sent it.
