installing DNN locally - problems with relative path
Last Post 2012-02-02 12:10 PM by Joseph Craig. 1 Replies.
Author Messages Informative
Prakasam SrinivasanUser is Offline
2012-02-02 12:00 PM
Instead of making tests on my live site, I recently seen various tutorials concerning installing DNN locally on my machine open with visual studio from dnn folder.
Everything is working well, but...
Images dnn 6 skin images and other images doesn't show.
when i edit that module the image url is
- /Portals/0/images/myimage.gif i have to give instead of that /dnn/Portals/0/images/myimage.gif
its work properly.
If I look into the HOST SETTINGS, I see:
- Relative path /dnn
On my live website, I have relative path which is empty...
can modify this ???
Joseph CraigUser is Online
2012-02-02 12:10 PM
Recently I discovered this very useful blog post: http://www.dotnetnuke.com/Resources...Hosts.aspx
So, instead of referring to your site as, for example, localhost/dnn you can refer to it as dnn.lvh.me. You will need to put the appropriate entries in your portalalias table.
This is an extremely clever and very nice solution.
RE: Deploying dnn by Sameer
Just sent it.
