jQuery Announcements Slider - Issue 68
Last Post 2012-04-16 07:46 AM by mpp global. 26 Replies.
Page 2 of 2 << < 12
bbqla19User is Offline
2012-01-09 10:19 PM
Great video, thanks. I have added the jQuery announcements Slider as per video instructions. I have applied this to my existing skin. However I am having difficulties in changing the dimensions of the slider, can you please advise which file controls this. Css or do I have to change something in one of the .js file?
Many thanks.
Mas
Joseph CraigUser is Online
2012-01-10 06:13 PM
You should be able to set the CSS for the element in the slider, or even the bounding element.
2012-01-10 09:37 PM
Thank you, I will have a go and see what happens.
gopinath ramalingamUser is Offline
2012-04-03 11:36 AM
my jquery function is not working in my dnn6 module pls any one help how to use jquery in dnn6
2012-04-03 11:39 AM
i am the beginner for module development how to use jquery in dnn6?jquery fn is not working in my module
2012-04-03 08:27 PM
When you have trouble with javascript or jquery, the best debugging tool is the developer tools built into or added to your browser.
I particularly like the took built into IE. Click F12 to bring up the developer tools window. You can enable javascript debugging, set breakpoints, trace code, etc.
So, give that a shot and IE will at least give you a clue as to the nature of the problem. If you need further help, report the error messages here.
If possible, a URL that shows the error is always helpful.
mpp globalUser is Offline
2012-04-16 07:46 AM
Brilliant post!!
But how to download video second?
Thank you for this.........:-)
[URL="http://www.mppglobal.com"]payment gateway[/URL]
Page 2 of 2 << < 12
RE: Deploying dnn by Sameer
Just sent it.
