After much frustration trying all sorts of variations myself and contacting the reseller tech team without a successful conclusion I wonder if anyone here can shed some light?
I have watched (over and over again) Lee's creating a parent Portal to use a subdomain.
The advice in the Reseller Choice interface seems very logical and straight forward. Unfortunately my reseller uses websitepanel (
http://websitepanel.net/) which seems to be a very common interface for Microsoft based servers.
The interface can create a subdomain web space into which you can ftp your own files.
Clearly this is not needed as a DNN portal is self-contained in the original TLD host folder.
Within the websitepanel interface in the TLD website area there is a 'headers section' which by default has the first field completed (see screenshot attached)
Header Name = X-Powered-By
Header Value = ASP.NET
Does anyone know what needs to go in these fields for the sub domain dnn portal to work correctly? It doesn’t seem t work no matter what I do and at present resolves to res://ieframe.dll/http_403.htm#
http://Mywebsite... The documentation for websitepanel is rubbish and unless you are very familiar with DNN the tech support people for the hosting don’t seem to have a clue.
