Advanced DotNetNuke Debugging - Issue 66
Last Post 2011-03-17 12:10 PM by Mr. MobileNow. 4 Replies.
Andy StephensonUser is Offline
2011-02-16 11:03 AM
    Add any comments or questions regarding the Advanced DotNetNuke Debugging tutorial from Issue 66
    Joseph CraigUser is Online
    2011-02-16 03:42 PM
    I think that this is going to be be a nice set of tutorials ...
    For those who don't have access to the full SQL Server or to the SQL Server Profiler tool, perhaps it would be nice to mention the name of the free tool. What is it?
    OlivierUser is Offline
    2011-02-17 10:31 AM
    when will video's 3, 4 and 5 be released?
    http://www.dnncreative.com/Tutorial...fault.aspx
    thanks for looking
    Olivier
    2011-02-17 12:00 PM
    Oliver,
    Starting with February, tutorials are being released one at a time.  If you go to the Issue page, you can click on a link to see the download schedule.  Video 3 is scheduled for March 2 and Video 5 for March 30.  I think that means that Video 4 will be out on March 16.
    Mr. MobileNowUser is Offline
    DotNetNuke Ninja
    2011-03-17 12:10 PM
    Hi Joe,
    While I haven't actually used the free tool, it is available from:
    http://sites.google.com/site/sqlprofiler/
    I hope ya'll are enjoying my series. I had quite a bit of fun recording them.
    -Tony Valenti
    DotNetNuke DNN Hosting
    DotNetNuke DNN Hosting UK
    I work for PowerDNN
    FCK Editor in DNN 6 by WinXnet
    is there a way to get the FCK editor working in DNN 6 - it has stopped funcitoning properly after an
    RE: Deploying dnn by Sameer
    Just sent it.
