You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
DotNetNuke®
DotNetNuke® Questions
Mixing up user data within DNN database
Last Post 02/24/2011 7:26 AM by
. 8 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Michael
02/10/2011 5:28 PM
We have several ASP.NET systems that are being considered for DNN conversion. Currently each of the systems uses its own SQL database and a common User/Member details database for authentication. We are not sure (1) if each system will run within its own DNN intance or it is better to have seperate intances. (2) If the system specific (Sensitive/protected)SQL tables, SP's etc should be stored within the DNN database or if it is a good practice to seperate system data from DNN specific details. (3) If there will be performance issues when multiple DNN systems all run under a single DNN instance sharing a single DNN database that contains system tables and DNN specifics for all. (4) What is the DNN guidelines for easy maintenance in such instances. Would appreciate any and all help. Kindest regards!!
DNN MVP
02/12/2011 12:00 PM
Each installation of DotNetNuke requires an instance of IIS and a MS SQL Server database. Each installation can host one or more sites or portals. All of these will be in the same database.
It is also possible to maintain one portal per installation, in which case each install will have its own database.
Often, the web servers (IIS) and the database are hosted on different computers.
How you do this will depend on performance, size of the site, number of users, number of simultaneous users, etc.
I prefer to keep unrelated sites/portals in separate installations. But you can certainly host multiple installations on a single IIS/MS SQL configuration.
We have multiple sites hosted on a system that features separate web server and MS SQL servers, but with multiple installations. We also have several sites hosted in a single installation. For low traffic sites that doesn't present a problem.
The real answers depend on the nature of the sites and the traffic that they must serve. I hope that is not too fuzzy of an answer to your question.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Michael
02/13/2011 4:07 PM
Thanks a lot Joe, As you say we should first get a handle on the performance requirement, size of the site, number of users, number of simultaneous users etc before proceeding. Having heavily accessed system data mixed up in DNN database seems a bit scary though. Will the page load / subsequent processing time etc be attrocious when the DB is being hammered by other apps including non-web applications that runs queries/reports etc.
Michael
02/20/2011 4:11 PM
Single VS Multiple DNN Instances
what if we have geographically seperated teams developing / supporting the individual (sub)systems/child portals that are to be implemented within a single DNN instance. Assuming each team has its own local test and UAT environments (having copies of productionLike DNN database for development and testing). How will the individual teams deploy their own modifications without affecting the others/systems? I see from posts on module development that Modules and Skins can be packaged. How about new pages or page changes? How about DB changes that arise outside of module, Skin package installations. Can page related changes be packaged from the individual development environments and installed on the production server? Won't there be conflicts even on database objects like TabID, Module ID..etc? We are hoping to build an SVN repository for tracking versions of existing source files. However I am not sure how would one keep track of the Page/Tab, DB changes when multiple teams contribute on top of the changes typically applied on bhalf of non-web apps.
Would appreciate any and all comments...
DNN MVP
02/20/2011 6:25 PM
Yes, you have identified the issues. Those all "might" be good reasons for having separate installations.
With Content Management Systems, and with the website being defined partly in the web directory and partly in the database, the software development model -- SVN, etc. -- doesn't work very well.
You can severely limit the number of people who can change the live site(s).
Can you can package up pages and sites. There's not an easy way to update a page from a dev site to a live site, except for the Enterprise version of DotNetNuke. As I understand it, though, the update/publish works only for HTML modules.
Joe Craig,
Michael
02/22/2011 11:20 AM
Joe,
Thanks a lot. We appreciate your comments very much. I guess we have a bit more learning and planning to do before pushing ahead full steam.
DNN MVP
02/22/2011 1:54 PM
I'll be happy to help ... just ask questions.
Joe Craig,
Michael
02/23/2011 10:53 AM
If we go with multiple instances of DNN running in production how will we handle the need to centrally maintain Users, UserRoles and UserProfiles? We have to avoid duplicating user profiles as a given user may have to access multiple apps with different/same roles. Can DNN be made to look at an external (common) "Authentication" DB for this purpose? Currently we have a common DB shared by all apps for user authentication/authorization.
DNN MVP
02/24/2011 7:26 AM
You can handle authentication with a custom authentication provider. Keeping a common set of users, roles and profiles is more difficult and requires other custom providers.
If all of your portals are within a single installation, you can use a module like Multi Portal User Sharing from Avatar Software. I am using it on one installation and, for the most part, it works well. There are a few minor issues, but not significant.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
DotNetNuke®
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
