Manager Users
Last Post 2007-02-22 11:00 AM by Rajan Gangadharan. 2 Replies.
Rajan GangadharanUser is Offline
2007-01-26 03:08 PM
Hope someone can help!!
We are trying to create custom My Profile page that will use the existing functionality of DNN's.
From what i gathered so far the suggestions was to copy the ManageUsers.ascx and related code and customize the code such that it meets our requirements.
I have managed to copy and edit the new ManageUsers.ascx but everytime i load the module the page references to original managerUsers.ascx. I found from the debugging mode that the page redirects to a page using the following code "Response.Redirect(NavigateURL(PortalSettings.ActiveTab.TabID, "MyProfile", "UserID=" + UserInfo.UserID.ToString), True)".
What am I doing wrong? How can I make this work?
Any help would be appreciated.
Andy HockUser is Offline
2007-02-22 05:50 AM
You should look for the 'MyProfile' record in the Tabs table? (don't remember off hand which one), and change it so it points to the tab id of your page. That should do the trick.
DotNetNuke and .NET web parts, web services, modules and code snippets.
2007-02-22 11:00 AM
Thanks so much Andy.
That did do the trick.
