Slideshow recommendation
Last Post 2010-09-10 12:35 AM by CDMeyer. 4 Replies.
CDMeyerUser is Offline
2010-09-08 08:25 PM
I'm looking for a recommendation for a simple to use fading slideshow module.  I have a banner area across the top of my page that I would like to fade between images and add links to the images to that a click would get you to a page with more info.  Free is preferred, but I am willing to pay for the right module.
I tried a jquery slideshow and the performance was very slow.  My banner is 950x220 so the images are pretty large.
Chris Meyer
Joseph CraigUser is Online
2010-09-08 11:32 PM
Engage Rotator is a commercial modules that will do this.
You might want to have a look at the free modules from Will Strohl and Oliver Hine.
Ultra Media Gallery is another choice.
2010-09-09 02:24 PM
Thanks.  I got a jquery cycle to work except that my dropdown menu drops behind the slideshow.  Can be seen here http://dnncefcnj.cdmeyer.com/Home.aspx
Any ideas on how to fix this?  I used the header of the module for the script and the content of the module for a table with a div and images.
Chris
2010-09-09 11:36 PM
You need to use z-index to the all of the menu and submenu items to appear on top of the slideshow.
If you add z-index:10 as an attribute to .MainMenu_MenuSubStyles, that will do the trick.
There may be a better place to add the z-index, but this works.
If you are wondering how I figured that out, look at this tutorial for skin troubleshooting techniques: Troubleshooting DotNetNuke Skins
2010-09-10 12:35 AM
that did it.  thanks a lot.
Chris
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
