Dynamic Forms Help
Last Post 2010-09-03 12:23 PM by Joseph Craig. 1 Replies.
Sloane879User is Offline
2010-09-03 04:11 AM
Can anyone help me with the following issue:
I've followed all the tutorials and setup a dynamic form.  After the end user clicks on the button to submit the form I've configured the message to display confirming and the end user has successfully completed the form.  Then the end user has the opportunity to click on the continue... button to be taken to another page.
The problem is that the form is quite long and when the end user clicks submit at the bottom of the form they can't see the confirmation message because it's displayed at the top of the page.  How can I route the end user to the top of the page when they click on the submit button so they can see the confirmation message?
Thanks in advance for anyone who can help me.
Sarah
2010-09-03 12:23 PM
You might want to redirect the user to another page if the form is submitted successfully.
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
