How to use Papayas Auto Upgrade for DotNetNuke - Issue 60
Last Post 2010-10-16 05:01 PM by Joseph Craig. 9 Replies.
2010-09-02 05:34 AM
    Add any comments or questions regarding the How to use Papayas Auto Upgrade for DotNetNuke tutorial from Issue 60
    Andrew CampbellUser is Offline
    2010-09-05 02:58 AM
    Hi Lee,
    Thanks for showing me this module. I have purchased the enterprise licence and updated 4 websites. In the past I have been reluctant to update and always paid someone to do it.
    As always keep up the great work, I appreciate your tutorials as they always make my job easy!
    Cheers,
    Andrew
    Dave HassallUser is Offline
    2010-09-17 01:37 PM
    Hi Lee
    Amazing....
    Definitely on my to purchase list
    Upgrading in the past has been too painful, but this looks like a great option.
    I even had a situation where I had purchased a demo module and the upgrade to the purchased version lost all my data - the backup only option would have saved me a couple of hours
    Thanks - great video tutorial
    Dave
    md-pvUser is Offline
    2010-09-25 02:46 PM
    Hi Lee,
    this module seems to be great and your tutorial is - as always -very useful.
    I ' m wondering if there's an easy method to find out which of my third party modules are suitable to which dnn version.
    I'm not sure if updating is so easy as you showed it when you use a lot of third party stuff .
    Any suggestion how to proceed in that case ?
    Matthias
    Joseph CraigUser is Online
    2010-09-25 03:44 PM
    No, there's not an easy way to check ... other than checking with each module developer.
    2010-09-27 09:40 PM
    Have just done my first test on a local host
    Initial DNN 4.5.0 tried to upgrade to 5.5.1 and got an error
    Second test upgrade to 4.9.5 OK then 5.5.1 Success
    All in All a brilliant module
    Dave
    2010-09-27 11:06 PM
    Going from 4.5.0 to 5.5.1 in on step is a big leap.
    2010-10-03 04:15 PM
    Agreed.....
    But the real beauty of this module is that the process is relatively painless so you can try the big jump and if it doesn't work roll it back and take smaller steps
    cmolicaUser is Offline
    2010-10-16 05:25 AM
    I am having trouble getting Papayas to connect to AS3. Do you know if I have to set a certain permission or bucket policy? I currently have full permissions for authorized user (AS3). I have even tried to test settings with Everyone set to full permission. Still No Luck.
    DNN 5.5.1
    Papayas 5.6
    Thanks for any help you can provide.
    Christian
    PS I guess the error I'm getting might be helpful...
    Test failed with message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
    2010-10-16 05:01 PM
    Have you tried contacting Papayas for help with this?  They certainly know more about the product than I.
    From the error message, the "trust relationship" is clearly an issue.  But, I'm not sure how or where to fix this.
    FCK Editor in DNN 6 by WinXnet
    is there a way to get the FCK editor working in DNN 6 - it has stopped funcitoning properly after an
    RE: Deploying dnn by Sameer
    Just sent it.
