NewsTicker Module
Last Post 2007-01-16 06:53 AM by dnncovered dnncovered. 0 Replies.
dnncovered dnncoveredUser is Offline
2007-01-16 06:53 AM
Dnncovered.com is proud to release their famous Newsticker module, Newsticker 3.1.0, compatible with both DNN 3.xx and DNN 4.xx. NewsTicker 3.1.0 is equipped with new features like Multiple RSS feed, ability to customize the styles of the news and links. Customization of the direction, speed and delay of the scroll and many, many ……… more, See Table 1.0 for complete list of features provided for NewsTicker 3.1.0 with different versions.
Free trail Version:
http://www.dnncovered.com/Store/tab...fault.aspx
Also Avaliable in different versions
Buy From Snowcovered:
http://www.snowcovered.com/snowcove...ageID=5971
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
