LOGIN and USER items.
Last Post 2010-09-01 04:13 AM by Joseph Craig. 10 Replies.
ollepUser is Offline
2010-07-08 05:18 AM
    Is the code for this 2 available somwhere?
    Would it be possible to use these in a module?
                < dnn:login runat="server" id="dnnLOGIN" cssclass="SkinObject" >
                  < dnn:user runat="server" id="dnnUSER" cssclass="SkinObject" >
    Cheers
    Olle...
    2010-07-08 01:27 PM
    The are skin objects, and all of the code is in admin/skins. They aren't compiled.
    2010-07-20 10:48 PM
    Thanks Joe
    Didn't relay get this, checked Admin menu / Skins, but couldn't find the code?
    Cheers
    Olle
    2010-07-21 01:31 AM
    The code for the skin objects is in the admin/skins directory.
    If you google around, there are some good resources on skin objects.
    2010-07-23 12:31 AM
    Alright! Will try that Joe.
    If you look at this one; www.aimartialarts.com
    Nina have here the login items in the bottom only, I want them in the top. Have put some basic hyperlinks in the left column - which doesn't look good, and doesn't have the feature of showing who's logged in.
    Guess I could go into the skin and stick a Log-in token in the left pane?????
    Olle...
    cube consultingUser is Offline
    2010-08-30 10:41 AM
    Hi Joe,
    I am such an idiot, I changed the login page to a new page I created, but forgot to add the login module on that page.. Now I can't log in anymore, please help!!
    Aad
    2010-08-30 01:39 PM
    2010-08-30 02:24 PM
    Hey Joe,
    No good. I changed the login page to my newly created page without the account login module on it.. I ended up re-installing the whole darned thing.. back to square one, for the umpteenth time by now..
    2010-08-30 04:25 PM
    It is possible to remove the specification of a custom login page by editing a configuration in the database.
    mgordonUser is Offline
    2010-08-31 03:22 PM
    ZOMG! This was the MOST Engineer Speak I've heard in a long time from you Joe!
    I had to read it many times to make sense in my non-logical brain. :-)
    Mark Gordon
    Webmonkey
    2010-09-01 04:13 AM
    Gosh, I'm not sure if this is a compliment or and admonition!
    informative!!!
    informative!!!
