Missing blog entries
Last Post 2010-07-30 02:36 AM by Joseph Craig. 2 Replies.
SixfootStudioUser is Offline
2010-06-24 02:53 PM
Hi, I've just added another sub blog to my DNN site and have done something that's made all other entries go missing. Has anyone experienced this before? Thanks
WinXnetUser is Offline
2010-07-29 05:17 PM
I never use the dnn blog - it always seems to have issues. If possible, you might want to move to a different blog. Most of our clients use wordpress and pull the blog in with feedreader lite (@25).
If that's not a possiblity, I hope you figure it out!
^_^
http://www.winxnet.com Emerson Bruce - http://chayadigital.wordpress.com
Joseph CraigUser is Online
2010-07-30 02:36 AM
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
