Documents module sorting does not work
Last Post 2007-01-09 08:37 AM by Lee Sykes. 3 Replies.
David PrimusUser is Offline
2007-01-08 06:45 PM
Sorting does not appear to work in the documents module. I have DNN 4.3.7 and Documents module 3.01.06 and SQL 2005.  I have three files, titled A, B, C, and D.  They sort as C,D,A,B.  None has a sort index, so they should sort by title. Also, if I try to set the Sorting to 'Title' (or anything else), it does not stick, but goes back to 'Sort Index' the next time I look at the settings. Thanks in advance for any help.
2007-01-08 11:06 PM
I've just tested it in 4.3.7 with 3.1.5 and it works ok. It sounds as though you are missing one vital bit.
In the sorting drop down list, select Title. - Then Click on Add Sort Order link to the right of this.
Underneath you should then see Title listed
Click on Update and all your settings should be stored.
You can add multiple elements to the sort order using this method.
2007-01-08 11:58 PM
Thanks, Lee. Indeed, sort is working fine!  I just did not know how to set it!  Your explanation solved the problem.
2007-01-09 08:37 AM
great, glad it helped, thanks,
DNN nav issue by imran shaikh
