What are the best modules to install?
Last Post 2010-06-02 02:10 AM by Joseph Craig. 2 Replies.
gtdriskiUser is Offline
2010-05-15 10:15 PM
Being fairly new to DNN,  I would like to know what modules experienced users feel are the best ones to install.  Obviously, you don't need a module unless you need its functionality, but some module types are needed in every install.  For instance what do you think is the best wysiswyg editor module, the best web form builder module or the best FAQ module.  I would consider both free and commercial modules.  Also, besides DNNCreative, what are good sites to find reviews and ratings of modules.
Thanks, Gary
Gary Driskill
WSI Internet Business Consultant
Ian SampsonUser is Offline
2010-06-01 06:15 PM
Hi Gary,
Take a look at this blog post on how to select a module.
Hope it helps - http://blog.glanton.com/2009/11/how...-from.html
Regards
Ian
Galnton.com
2010-06-02 02:10 AM
That's good advice.  The most important question when it comes to module selection is ... what is the functionality that you need?  That will certainly limit and focus your choices.
That said, I've seen some really nice sophisticated sites that use mainly Text/HTML and Links modules.
