JQuery Validatoin Plugin in DNN
Last Post 2010-04-25 08:52 AM by Eurocenter. 0 Replies.
EurocenterUser is Offline
2010-04-25 08:52 AM
Hi All,
I'm trying to use JQuery Validation Plugin (http://bassistance.de/jquery-plugin...lidation/) to do client side form validation in DNN modules. Since I can't access the form element from a dnn module I tried selecting each control and invoking validate method on each.
Eg :
    jQuery(document).ready(function() {
        jQuery("#uxTitleTextName").validate();
How ever nothing gets invoked prior to the form being submitted thus no client side validation logic.
I have both the jquery js and validation js inside the section of the page. Can you please help me by pointing to a direction where I could be doing something wrong.
EC
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
