Edit Catalook MiniCart Skin
Last Post 2010-06-10 09:54 PM by Eli. 4 Replies.
PrimusUser is Offline
2010-04-22 01:26 PM
Hi, I tried to edit Catalook MiniCart skin using the Edit Skin Editor in the store after I save the new skin the default skin keeps showing up please tell me how can I fix that. I also noticed that after I edit any Module skin it dosent work please tell me what is wrong?! Note That I use trial version. Best Regards,
2010-04-22 03:57 PM
I tried every possible way I think because am using Trial vesion the Skin do not change.
2010-04-24 01:17 AM
Have you tried to get support from the Catalook developers? There is also a Catalook help site run by Nina Miers that seems to be pretty good.
2010-04-24 10:36 AM
I tried Both but I didnt get any Answer thanks
EliUser is Offline
2010-06-10 09:54 PM
The trial version does not allow you to change the skin. This is listed in the limitations of the trial version.
