Implementing ISearchable
Last Post 2010-09-02 06:33 AM by Anton Burtsev. 2 Replies.
Stuart DawsonUser is Offline
2010-04-15 11:17 AM
Hi I have a custom news module. To display a news article I use a single page (News.aspx) that looks at the querystring for an articleId and obtains the article from the database / displays the article within the page. My problem is in implementing ISearchable, my articles appear in the search results but the URL just points to News.aspx. I need it to be, for example, News.aspx?articleId=23. Is there any way to achieve this? My thanks in advance for any help! Stuart
2010-04-15 12:10 PM
This is a question that is better suited for the developer forums at DotNetNuke.com, I think.
Anton BurtsevUser is Offline
2010-09-02 06:33 AM
Hello, Just assign GUID property as follows: SearchItemInfo si = new SearchItemInfo(...) ... si.GUID = "articleId=" + article.ArticleID
Anton Burtsev
Develop For DotNetNuke With Pleasure
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
