SSL - Module & IE7
Last Post 2006-12-28 08:38 PM by Aleks Radko. 0 Replies.
Aleks RadkoUser is Offline
2006-12-28 08:38 PM
I am having a problem with IE7, when I go to a page that is an SSL protected page (SSL Module installed) the text on the page gets changed to different fonts and some of the formatting gets rearranged,   Again this only happens using IE7 and I understand IE7 handles SSL somewhat differently.
Anyone have any suggestions where to focus troubleshooting this issue?
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
