DNN with Javascript Disabled
Last Post 2010-03-24 02:05 PM by WinXnet. 2 Replies.
Abhishek TrivediUser is Offline
2010-03-20 06:48 AM
Hi All,
I have found my self in bit of trouble.
As per my application requriement, i need to handle the situation where Javascript being disabled by the user.
I am using DNN 5.1.4 version, what is happening is all validation controls, links, menu all are either not working or throwing errors.
Please suggent me the proper solution.
Abhishek Trivedi
2010-03-22 08:40 PM
You're going to need to enable javascript. DotNetNuke doesn't work well with javascript disabled.
WinXnetUser is Offline
2010-03-24 02:05 PM
You can get a skin to work with javascript disabled with some effort and good css (you can't use the solpartmenu - it will not appear without javascript), but you will not be able to do any administration or editing without it enabled.
So, develop the skin first so it works with javascript enable and disabled. Then enable javascript to do content entry, etc.
Also, some of the modules rely on javascript. You will need to test each module individually.
GeishaMX ^_^
http://www.winxnet.com Emerson Bruce - http://chayadigital.wordpress.com
