Firefox SWF file
Last Post 2010-03-25 02:45 PM by Joseph Craig. 4 Replies.
ce221User is Offline
2010-03-18 04:08 PM
on my dnn site it have a text/html that has the following attached code this displays fine in IE but will not display in firefox any help would be great.
1318133852171.txt
Joseph CraigUser is Online
2010-03-18 05:12 PM
I recommend that you use the free DigFlash module from dignuke.com. I've found it to be a very reliable way to incorporate flash files in DotNetNuke sites.
WinXnetUser is Offline
2010-03-25 01:15 PM
Firefox requires a different setup - try using flash to publish an html page with the flash in it. Now copy the code from the created page to an html module.
This usually is the quickest way.
Emerson
http://www.winxnet.com Emerson Bruce - http://chayadigital.wordpress.com
2010-03-25 01:17 PM
Of course, you will need to change the location of the flash file (ie: Portals/0/flash/myflash.swf) everywhere it appears in the code (I think it appears 3 times if memory serves, but it may be two).
2010-03-25 02:45 PM
That is why I prefer to use something like DigFlash.  You can administer the module easily, and you won't mess up the code that embeds the flash object.
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
