Run exe/dll from DNN?
Last Post 2010-03-18 11:39 PM by ollivogt. 4 Replies.
ollivogtUser is Offline
2010-03-17 10:06 PM
Hello, is it possible to run an external application from within DNN - for instance doSomething.dll DNNuserName or externalDoSomething.exe DNNuserName There is no need for a return value. Does anyone know an extensino for this? Regards Oliver
2010-03-17 10:09 PM
Do you want to do this on a schedule, or in response to an event such as a mouse click?
If the former, you can create a "scheduled task." It's a fairly simple process.
If the latter, you could attach a custom "onclick" javascript to the link. The only trick there is in writing the javascript code to start up whatever it is that you want to start.
2010-03-18 12:33 AM
excellent!!! scheduled task looks good - do you have any hint where to start the search? Many thanks for the VERY quick response.... ;-Oliver
2010-03-18 01:08 AM
I did this several years ago, so I think that what I found must have been in the "Professional DotNetNuke 4" book.  I think that Mitchel Sellers covers it, briefly, in his book on module programming.  A Google search for "DotNetNuke Scheduled Task" turns up this.
As Rafe shows, it's a fairly simple thing.
2010-03-18 11:39 PM
Thank you. I have a look at it....
Regards
Oliver
