How to upgrade core module?
Last Post 2010-03-18 01:29 PM by LeeWebDev. 2 Replies.
LeeWebDevUser is Offline
2010-03-17 01:32 PM
I can't believe this is so hard to find instructions for, but how do I upgrade to the latest version of a particular core module? Specifically, the Events module. I downloaded the latest version (5.00.03) zip file from CodePlex. Now what?
David
2010-03-17 03:04 PM
All you need to do is install the downloaded core module in exactly the same way as you would install a new third party module. DotNetNuke will then upgrade the module.
Make sure that the latest version of the core module is compatible with the DotNetNuke version you are running.
I would suggest you backup your website and database before upgrading any modules just incase any data is lost.
How to install a Module in DotNetNuke 5
2010-03-18 01:29 PM
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
