DataSpring Opt In Module - Scheduler Question
Last Post 2010-03-17 01:05 PM by wynnjon. 2 Replies.
wynnjonUser is Offline
2010-03-16 08:42 PM
Hey-
I was wondering if anything special had to be done to keep the site alive so that the scheduler inside the Opt In email module from datasprings would work correctly?
Does anyone know?  I just finished the tutorial and nothing was mentioned around that- so I assume no... but from what I know of these DNN sites, the site must be active for the scheduler to work?   Is this true?
Thank you,
Jones
2010-03-17 11:58 AM
From what I can remember, yes I think the site does have to be active for the scheduler to be working correctly.
In any case, I would make sure you site is active so that when a user first visits the site the page is loaded as quickly as possible rather than waiting 17secs for the server to load the website into its memory.
checkout:
Performance Tips - Fast Site - Keep Alive Tools - Hosting
2010-03-17 01:05 PM
Thank you! Your advice and training is always so great and always appreciated!
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
