Efficient Contacts Manager
Last Post 2010-03-15 05:20 PM by etadmin. 0 Replies.
etadminUser is Offline
2010-03-15 05:20 PM
Currently I'm using the Forms and List module, it has about 1500 contacts and 40-50 fields per contact, but has VERY inefficient lookups.  I've also tried the Onyak tech My Contacts module, but it is still too buggy to give to users to use.
Does anyone have a recommendation on a personalized contacts manager that has efficient lookups?
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
