Google Verification Code Question
Last Post 2010-03-14 06:30 PM by BCRose. 1 Replies.
BCRoseUser is Offline
2010-03-14 05:57 PM
Where do I place the Google verification code?
I have been searching this site but cannot find any relevant information.
2010-03-14 06:30 PM
I found the solution. If anyone else wants to know this information you must go to your home page and select PAGE SETTINGS and go to Advanced settings and place the code in the page header section.
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
