daisy chain continuous loop of all the flash files
Last Post 2010-03-11 05:21 PM by mlorence. 2 Replies.
mlorenceUser is Offline
2010-03-10 05:10 PM
I have an install of dnn 05.02.02. I had a flash guy make a movie for my home page. There are 6 files.. container.swf, 1.swf, 2.swf,3.swf,4.swf, 5.swf. With all 6 of these files on my desktop, I can open container.swf in Flash9 or any browser and the daisy chain continuous loop of all the files works perfectly. In my dnn site I can only choose 1 file in the Media Module.
Questions: What direction can you give?  How can I mak this work as it does on my desktop?
Joseph CraigUser is Online
2010-03-11 01:07 PM
I would imagine that each file includes a URL to other link to the next file. That works fine on your desktop: each file looks in the "current" directory for the next one. When you do this in DotNetNuke, something goes awry. Ask your flash designer how the files are linked, and then you'll need to figure out how to do that in the context of your browser, which is where the flash files are played.
If you can provide some details on how the files are linked, perhaps we can help you figure out how they should be linked.
2010-03-11 05:21 PM
I made a test html page in Dreamweaver and it works perfectly, just as it does on my desktop. I used the iframe core module and it woks!
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
