Issue 52: OWS Login Module
Last Post 2010-03-08 07:10 PM by David P. 0 Replies.
David PUser is Offline
2010-03-08 07:10 PM
    I want to upload a file during user registration. Ive got this working now by just creating my own table. I can't use ows.Fecth becuase its a file upload. I check for the existence of a form variable to determine whether the module should display the user reg form, or whether it should process the reg, and display the confirmation. In my instance when the form submits, my reg actions are completed and according to the event viewer my confirmation page is displayed. However, the page then reloads and a blank user reg form is displayed. This is not the desired effect. Can somebody point me in the right direction. I am attaching config. Thanks, David
    138103978071.txt
    RE: user access by Kaustav
    Thanks for your help. I've created a user named kaustavkar and password is kaustav. I've ass
    RE: HTML editor adds target="blank" by Abraham Tameru
    yes, there is a dropdown list and I select "none". This problem occurs when I also insert documents.
    RE: Slice a Site by Joseph Craig
    Are you looking for an "image map"? If so, that is a standard HTML item, so look in a good HTML ref
    RE: user access by Joseph Craig
    You should probably change those passwords now as your site is totally unprotected.
    Slice a Site by Dan Glanton
    Is there a tutorial or is there a way to slice an entire image for a site and allow hover and click
    RE: Installing DNN 6 as a Website not application by Dan Glanton
    Yes. I couldn't believe how easy it was to install DNN this way and it allowed me to create as a web
    The only change that I made was to give the newrole permission to see the Admin, File Manager page.
    Thanks a lot for your help. Could you please let me know what changes you made? I want to
    RE: Presentation of XML-data by Joseph Craig
    SQL Server has a "bulk load" feature for importing XML data. To do this once a day, you'll need s
    RE: HTML editor adds target="blank" by Joseph Craig
    Go to Host, HTML Editor Manager and check exactly which editor is selected. When you click on the
    The kaustavkar user account did not have permission to visit the Admin, File Manager page. I added
    RE: Presentation of XML-data by Morten Frederiksen
    Thank you for your reply. What would be the easiest way to import the data into the DNN db? The X
    I am using dnn CE 06.01.02 (98) and my editor is the Common HTML editor 6.1.2. By the way, the p
    Sure. Create a special role for that user, and give the role access to the pages and file director
    Hi, I've created a user and I would like to allow him to access the Admin and it's subpages. Als
    RE: Installing DNN 6 as a Website not application by Joseph Craig
    If you are referring to the helper available from mikevdm.com, yes that is a good one.
    RE: DotNetNuke Error "An error has occurred" "An error has occurred" after moving site from Localhost to Production site by Joseph Craig
    The error message refers to problems loading your skin. I would double check that all files were
    Which version of DotNetNuke are you using? Which editor are you using?
    I found a MakeDNNSite Application that took care of everything in matter of seconds. This one was pu
    RE: DotNetNuke Error "An error has occurred" "An error has occurred" after moving site from Localhost to Production site by Maria
    I am having the same situation but I have not added any modules. Local host is working fine but whe
