Creating a new user
Last Post 2011-09-23 01:17 PM by Joseph Craig. 4 Replies.
kaushalUser is Offline
2010-03-08 11:57 AM
    friends,
    a little doubt in creating user internal process (how dnn is creating user)
    suppose i have 2 portals ABC and XYZ.
    one user xxxx came and registered him self at ABC portal with username as "xxxx".
    second user came and registered him self at XYZ with the same username "xxxx".
    first thing is dnn is allowing me to create user with the same name under different portals.
    So, I understand that internally there is only one user "xxxx" as the username under membership and this user is mapped to two portals - XYZ and ABC..
    is it correct? If so, then I going to be in a big problem
    Mocrosoft MVP [.NET/ASP.NET]
    Joseph CraigUser is Online
    2010-03-10 12:15 AM
    DotNetNuke uses the ASP.NET membership scheme. I haven't tested, but I am reasonably surethat the same username can exist for distinct users in different portals. Have you tried it?
    express martUser is Offline
    2011-03-30 06:43 AM
    thanks
    avavineyUser is Offline
    2011-09-23 12:41 AM
    the same username?
    2011-09-23 01:17 PM
    Have you tried it?
    I'm confused by this, too.
    We are running DNN 6.x
    You should be able to use CE even if you have a high traffic site. To develop your site without p
    RE: Rename or move site from domain name to subdomain name by Joseph Craig
    It is easy. 1. Go to Admin, Site settings and add a Portal Alias for new.websitename.com 2.
