FCK editor Toolbar
Last Post 2010-03-08 09:02 PM by Lee Sykes. 1 Replies.
r557User is Offline
2010-03-05 06:09 PM
Not sure what the possible issue is, but i've removed buttons from toolbars in 2 sepearte fck config js files but the buttons still appear.  Mainly, i want to remove the style dropdown and the font dropdown.
also, set my toolbar as the default in the web.config file.
I have the editor area CSS configured to dynamic, so would that override anything?
2010-03-08 09:02 PM
The toolbars are defined directly in the FCK editor. - Using a text / html module, go to edit.
Click on "Show Custom Editor Options"
At the bottom is "Editor Toolbar Options" this is where you configure the various Toolbar views dependant on security roles.
Further information is here:
FCK Editor Custom Toolbars and Security Roles
