Feedback Module Categories
Last Post 2010-03-09 12:42 PM by Lee Sykes. 5 Replies.
twhite902User is Offline
2010-03-03 03:12 AM
Is anyone else having problems with Feedback Module categories? The module works fine when it's set up with a single "Send To" email address. When I add categories with seperate email addresses in the values, and select "use values to send to", I get an error message that the Feedback Module is currently unavailable. I followed the new video tutorial step by step, so not sure what the problem is. Thanks, Tom
2010-03-03 11:54 AM
In the feedback Lists area:
Have you added any subjects?
If you have, make sure that the Value for any subjects is a number - exactly as we did in the tutorial
2010-03-03 05:38 PM
I have not added a subject list. I have the Subject on "None Specified", and checked the "Can Edit Subject" radio button. Do I need to add some subjects to make the category email list work? Tom
2010-03-08 09:18 PM
You should not have to, what version of DNN are you using? We recently found problems with earlier DNN5. versions
2010-03-08 11:12 PM
I'm using DNN 5.1.4
2010-03-09 12:42 PM
Yes, it's 5.1.4 where I also have come across the error. I would suggest you upgrade to the latest version of DNN and it should then work ok.
How to Upgrade DotNetNuke (Auto Merge Method) (v4.6.2 to v5+)
Make sure you create a full backup of your website and database before attempting to upgrade, I would also suggest you test the upgrade on a local copy of your live webiste. The 2 tutorials above should walk you through everything you will need to know.
