AJAX /JQuery ModalPopupExtender
Last Post 2010-03-01 05:02 PM by Vinny. 0 Replies.
VinnyUser is Offline
2010-03-01 05:02 PM
Hi all, Can anyone point me in the right direction to a tutorial on how to properly add a progress indicator using the ModalPopupExtender in a DNN module? Thanks.
Vinny M.
IMI Software, Inc.
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
