OWS How to access multiple Datatable results ?
Last Post 2010-03-04 12:16 AM by Bizcom.it. 2 Replies.
Bizcom.itUser is Offline
2010-02-28 11:29 PM
Hello , in a custom XML query (but it come true also in a standard SQL multiple select statements) the results are mapped to multiple datatables : the statistics debug view can be confirm it. How can I map the 2° , 3° etc table values in the detail template or in any other templating in OWS ? If I write [fieldname] or [fieldname,queryname] I can access only to the first datatable of that query : there is a sintax that permit to access the others? Thanks in advance Roberto
Paul DeschenesUser is Offline
2010-03-02 05:00 PM
Each dataset in a query template is ordered by index number so that if your query template was
Select username from users
Select rolename from roles
you could access the results of both in your detail templates by referencing the first query as 0 and the second as 1
[username,0]
[rolename,1]
Paul Deschenes
DNN Creative OWS Tutor
2010-03-04 12:16 AM
Thank you !
This can run only in a Query Template ?
And what about Query[queryname] action ?
in this case the common sintax is
How can I access to n-result in a multi result Query action ?
Roberto
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
