DNN Survey Module
Last Post 2006-12-28 08:29 PM by Aleks Radko. 2 Replies.
Aleks RadkoUser is Offline
2006-12-16 06:08 PM
Where can I get more information on how to use and setup the the survey module  on a page(s)?
I'd like to allow the public to take the survey but only allow registered users to view the results.   Finally does it come with any administor capabilies to change or update the collected data?
Déclic Vidéo FXUser is Offline
2006-12-28 08:10 PM
Check the manual which comes with it. Or in the project section of DNN. It is well explained (I am also a newby, but managed to understand the manual).
DV FX
2006-12-28 08:29 PM
Thanks for the input I'll check it out.
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
