Localizing Skins and css dynamically based on language selected
Last Post 2010-02-09 10:15 PM by Joseph Craig. 1 Replies.
SadabaharUser is Offline
2010-02-09 03:22 PM
Hi, I want to dynamically assign a skin and CSS based on the language selected. Different pages has different skins, and each skin has 2 copies, one for English and one for Arabic. I want that if a user has selected English language, English skin will be selected for a particular page and if Arabic language is selected, Arabic skin is assigned to the page? can any body help me out?
2010-02-09 10:15 PM
I think that you'll need to create a custom "skin switcher" that does this based on the selected language. I have not looked at doing anything like this, so I can't give specific advice.
