Recomended DNN version?
Last Post 2010-02-09 10:15 PM by Joseph Craig. 1 Replies.
lolornUser is Offline
2010-02-09 03:10 PM
What version of DNN would be recommended for creating a new site? Has DNN 5.2 turned out to be as stable and good as rumored? Thanks
2010-02-09 10:15 PM
Version 5.2.2 is just fine.
DNN nav issue by imran shaikh
