DotNetNuke Recycle Bin Tutorial - Issue 53
Last Post 2010-02-10 09:12 PM by Joseph Craig. 2 Replies.
2010-01-29 12:25 PM
    Add any comments or questions regarding the DotNetNuke Recycle Bin tutorial from Issue 53
    frank caoUser is Offline
    2010-02-10 08:46 PM
    I couldn't find a deleted module in recycle bin. Is there any other way to recover it? I got the moduleID and TabModuleID from log viewer.
    2010-02-10 09:12 PM
    If you can look into your database, find the module in either the modules or tabmodules table (I'm not able to look into a DotNetNuke installation right now, so I can't check).  If it is there, you should be able to manually change the field that determines if it is deleted or not.
    These tutorials may have some useful information:
    Don't forget to make a backup copy of your database before you do this.  You may need to undo things.
