Upgraded to 5.x, the menu dissapeared and can't login - Solution
Last Post 2010-02-16 03:21 PM by gerard gillman. 23 Replies.
Page 1 of 212 > >>
2010-01-15 11:39 AM
I've just upgraded a live website from 4.9.2 to 5.2.1 using the upgrade package, the upgrade completed successfully, but when navigating to the site the menu is no longer displayed and the Login and Register links no longer work.
The solution, press CTRL + F5 to reload the page and clear the cache, this will load in the new menu and the correct login and register links.
Hope this helps,
gerard gillmanUser is Offline
2010-01-22 07:01 AM
I had same problem with my web site.  i have upgraded the v5.2.  and now I can't login. and give me error on the page.
what is going on.
2010-01-25 09:19 PM
did you press ctrl + F5
If so, what is the error you received?
Did you upgrade with the dotnetnuke upgrade package?
Do you have a backup from before you upgraded?
2010-01-25 09:26 PM
yes i did. it I used my work computer. i do not have any problems. becuase I using IE 6.0. if I used it at home computer. I get javascript errors. with my home computers i using IE 7.0. Do you know why this happening.
Gerry
2010-01-25 09:30 PM
do you have a URL to look at?
2010-01-25 09:34 PM
2010-01-26 12:02 AM
I'm not seeing errors with Firefox, IE8, or IE8 in compatibility mode.  I looked at the home page and clicked the login link.  In all cases I get to the login page.   I was able to Register, and I logged in and out successfully.
2010-01-26 12:14 AM
How come I got errors in status bar. On my PC. I am running this on Microsoft Vista Ultimate. I have Visual Studio 2008 Express edtiion on the PC. And I click on the login Link just freeze up.
2010-01-26 12:15 AM
also I got IE8 Also on my PC.
2010-01-26 12:41 AM
I have also Firefox on pc. I try with fiefox and just freeze up on me
2010-01-26 06:26 AM
guys probably gave up on me. i guess you no suggestion for me.
2010-01-26 08:28 AM
I've Just tested it in Firefox and IE8 and I can view the menu and register and log in as well.
All I can suggest is you clear the cookies and cache from your browsers and see if that helps,
2010-01-26 01:24 PM
Lee and I both have managed to visit your site, register and login.  So, I'd guess that there is something wrong with your browser.  Have you tried Lee's suggestion?
2010-01-26 02:17 PM
Yes I did. I even try reseting IE Back to oriignal settings. and didn't work either. i trying full virus scan on my pc. I have macfree on my pc. I think the only thing I can do reload the operating system full scratch.
I have a response back from web server. here is the response don't make sense to me.
[Jan 26, 2010 6:57:13 AM]
A: Could you please provide us the smtp settings that you have put in the script, so that we can check those and get it sorted out for you.
2010-01-26 02:33 PM
Don't reload the OS.  That's not needed.
What is that message a response to?
2010-01-26 03:02 PM
if not Needed to reload the OS. Then how can i fixed this problem.
here is orignal question I ask my server company.
[Jan 24, 2010 9:08:06 AM]
Q: I have a problem with Javascript. on my local machine its work fine. but I when I try to access my web site. it gives me javascirpt errors. I am using Visual Studio 2008 Express edition. and Running Microsoft Vista Ulimate on local machine. Do you know why this is happening.
[Jan 24, 2010 11:24:50 PM]
A: Please let us know the exact URL that throws error for further assistance.
Have a nice day!
[Jan 24, 2010 11:58:04 PM]
Q: http://www.germaninpittsburgh.org/
[Jan 25, 2010 1:19:13 PM]
Q: can I ask what is going on with this supoort ticket
[Jan 25, 2010 1:30:41 PM]
A: We are working on your issue and you will be updated shortly.
2010-01-27 02:13 PM
As we still are trying to figure out what the problem is, I don't know how to fix it.
It is true that reinstalling the OS on your computer may do the trick, but that seems an excessive step.  Have you tried a browser other than IE?
2010-01-27 03:38 PM
I did used firefox.  when I used firefox. it does not give any errors. but freeze up on me.  since you can register .  I think I got virus on my machine. that its causing me not do anything with javascript.
Thanks for giving me ideas
2010-01-27 05:43 PM
Definitely something wrong.
(A virus infection that you can't otherwise figure out IS a good reason to wipe and reinstall.  See Lee's notes about using virtual machines, too.)
2010-01-27 06:00 PM
can you give me link to "Lee's notes about using virtual machines"
Page 1 of 212 > >>
informative!!!
informative!!!
