How to change primary domain?
Last Post 2010-03-11 07:39 AM by aventhika. 7 Replies.
Patrick RyanUser is Offline
2010-01-14 06:25 PM
I've searched, searched, and searched some more. Does anyone know of a way to change the primary domain in dotnetnuke?
For example.
You start a website and install it on the domain: mywebsite1.com
Then you create a domain alias called: mywebsite2.com
You add that alias under ADMIN in dotnetnuke.
Is it possible to later change the primary domain to mywebsite2.com, and make mywebsite1.com the alias?
Any help would be greatly appreciated.
- Patrick
Néstor SánchezUser is Offline
2010-01-15 03:41 PM
Enter the website with the second domain alias, delete the first, then remove from IIS/DNS/Firewall, etc
2010-01-15 03:51 PM
Missed the change order spec, you should be able to reorder. What version of DNN do you use?
2010-01-15 04:14 PM
DNN 5
I'm not sure I truly understand your process, dealing with IIS.
2010-01-15 09:09 PM
Since you want to keep the aliases, but have them in different order: 1. First login to the site using alias "B" 2. Delete alias "A" clicking the red x. 3. While still using the "B" alias, add alias "C" with the same info alias "A". As long as Alias A and B show up as host header in the IIS site, you should not have problems.
2010-01-20 03:03 PM
In my hosting provider settings I have two domains listed.
Domain A
- Domain B as alias
In dotnetnuke I have the two domains listed in the same manner.
I want to change it to where domain B is the ONLY domain and delete Domain A completely from the hosting provider and dotnetnuke.
Is this something my hosting provider needs to help me with? Dealing with IIS? etc?
Thank you for your help.
Joseph CraigUser is Online
2010-01-20 07:36 PM
If you delete domain A from the portalalias table, then DotNetNuke will quit servicing requests for that domain.
You should probably also configure IIS to do something with requests for the domain that you are removing.  Also consider DNS implications.
aventhikaUser is Offline
2010-03-11 07:39 AM
Hi it is an easy ,for that change visit here ,i am using this site only for my change.All the Best.
informative!!!
informative!!!
