Nav Menu v2 for DotNetNuke v5 - Issue 52
Last Post 2011-03-15 11:43 PM by Joseph Craig. 24 Replies.
Page 1 of 212 > >>
2010-01-06 07:49 AM
    Add any comments or questions regarding the Nav Menu v2 for DotNetNuke v5 tutorial from Issue 52
    KyleUser is Offline
    2010-03-16 04:50 AM
    What are the advantages of setting the RenderMode to UnorderedList for the Nav Menu? How can this be done?
    2010-03-16 08:39 PM
    Here is a nice little blog entry on the subject.
    (Basically, though, this gives you a nice and clean way to start styling the menu ... perhaps at the expense of some complexity and a learning curve.)
    2010-03-17 12:00 PM
    To be honest if you wish to use an unordered list menu I would look at snapsis.com menu, I much prefer their CSS menu to using the NAV menu in unordered list mode - I find the code in snapsis is cleaner.
    TailoUser is Offline
    2010-04-02 02:31 AM
    First of all I like the tutorials and the way the are presented, especially for someone who never used cms or dnn.
    My question is, I usedd the image nav tutorial,
    it works on local install but once i trensferred the files to godaddy hosting the menu looks weird (its the same dnn install on both local and remote dnn 05.02.02). basically you cant see any other images except the home and admin and host use the 2nd menu image after home, i also uploaded your files
    to test on both servers and same thing, any idea what it could be causing it, maybe some dnn option
    remote host mode
    http://img87.imageshack.us/img87/1361/ex1w.jpg
    local host mode
    http://img101.imageshack.us/img101/2847/ex2k.jpg
    2010-04-02 03:33 AM
    Never mind my previous question, i didnt create pages in the remote install. oops
    chrisoUser is Offline
    2010-06-03 06:01 AM
    Hi guys,
    Does anyone know of a way to configure the Nav Menu so that an item(s) at the Root level are section headers/labels (i.e. they aren't links to a page). When rolled over, these simply expose the sub menu beneath them?
    You see this fairly commonly. As an example http://www.bunac.org/usa. The white tabs across the top do not link to a page, but are just section headers for the sub menu beneath. The exception is the first tab (USA Home) that links back to the home page. This is the type of arrangement I'm trying to replicate.
    Is this possible with the Nav menu? If not, is there a different navigation control that anyone knows of that might work better.
    ~Chris
    2010-06-04 12:26 PM
    For those items you want to use as "section headers" create the pages but mark them as disabled in the advanced section of page settings.  They will appear in the menu with their descendants, but they won't do anything else.
    2010-06-07 07:54 AM
    Hi Joe,
    Thanks!  That works great.
    Do you happen to know if that would affect SEO at all?  I'm just wondering if those "section headers" pages are disabled if Google or other search engines will be able to index the content in the sub menus?
    Thanks again,
    ~Chris
    2010-06-07 11:26 AM
    That won't have any effect on indexing your site.
    2010-06-08 05:20 AM
    Great. Thanks again, Joe.
    ~Chris
    letoUser is Offline
    2010-06-17 06:00 AM
    Hi!
    I am using two Nav menus horizontal in my skin. When I go from a page in the mainmenu to a page in the submenu the first item in that menu is getting a hover effect, even if I am not clicking that one. It just happens when switching from main to sub menu and the opposite way.
    The css class that affects it is .subMenu .hov and .mainMenu .hov
    As I can see, it is the same problem in the DNNC_Simple_Skin_NAVMenu2_i52_code. Anyone
    knows how to get around this problem?
    JernejUser is Offline
    2010-09-05 10:28 AM
    I can't make menu centerd on page, can somebody help me?
    2010-09-05 01:29 PM
    You can do something like this:
    < div class="myMenu">
           < div class="myMenu1">
                  < dnn:SOLPARTMENU runat="server" id="dnnSOLPARTMENU1" />
           < /div>
    < /div>
    Then, style myMenu1 to be less in width than myMenu, and also set it to margin:auto.  That will center myMenu1 in myMenu.  You may need to play with padding to get the left side of the menu exactly where you want it.  Remember that adding menu items will require changing the style.  You may also find that setting the display mode to inline may make some styling easier.
    Hopefully, someone has a better suggestion.
    Martin PetersenUser is Offline
    2011-01-23 02:53 PM
    I have just worked my way through the tut's regarding the Nav Menu Provider - excellent tut's
    Now, I have implemented ALL that's been shown in the tuts, but the 2 things that WASN'T covvered, seems to be the 2 thing's I am having problems with...
    Root menu Items works like a charm - no problems there.
    Sub menu items also works excellent...
    My problem is .first and .last - Oh, and those WERE covered - the uncovered items I'll get back to later....
    When setting a background image to those 2 items, I get a second cell for those menu-items, which also shows the background image, and that messes up the menu-design - I expect it to be ShowChildren cell for the submenues, since the cells appear to the right of the menu item itself.
    So Question : How do I hide those cells for those 2 menu-items?
    Next, the things, that wasn't covered :
    BREAK and ICN.
    I cannot seem to get a menu-break into my menu... I've set the .break class to show a background image, but it wont show...it doesn't even show the 1px solid red - border, that i've set (as per recommendation in the tut's)
    The break-class is set on the .m class and the .mi class (like this : .m .break and .mi.break td)
    Secondly, I really want the ICN class hidden - througout the Menu - and also the Indicate-children cell (which I suspect is causing the problem mentioned in regards with .first and .last classes)
    So, I really need some guidance.... or just spin me around and point me in the correct direction
    Kinde regards,
    Martin Moesby
    2011-01-24 10:51 AM
    A tiny update on this question: I've managed to get the menu look as designed, by NOT padding the ".menu .m" class, instead the I've padded the ".menu .m .txt" class and setting the background image for the ".menu .mi td" class... But I still have an issue with the ".break" class.. When setting a background on the ".menu .m" class, the seperator defined in the ".menu tr.mi" class shows up...., but if the backgound images is defined in the ".menu .mi" class, the seperator is not visible - I guess it's being overridden by the ".menu .mi td" class... So, if anyone's gor some kind og direction I should turn, I'd be really appreciative
    2011-01-24 03:00 PM
    Problem solved.!
    2011-01-24 05:45 PM
    Great!  What was the secret?
    2011-01-24 11:19 PM
    Hehe, yeah, that's a little complicated, but I will try to answer the best i can.
    First, I have to explain, what caused the issue in the first place:
    Every .mi item consists of 3 td cells : 1 for the icon, 1 for the menu text and 1 for the child indicator.
    the 1st cell is hidden using menu .m .icn { display:none; } - so that wasn't difficult
    2nd cell - well, that's gotta be there
    3rd cell is hidden  using the "IndicateChildren=False" on the Nav SkinObject.
    BUT - and this caused me many hours of grief - when padding the .menu .mi class, the 3rd cell becomes visible again - with the same width that .menu .mi is padded with (i.e. padding:15px caused the 3rd cell to be 15px wide) ... and if the .menu .mi  class also has a background-image definition, that definition applies to all 3 cells in the .mi class - and thus the image will also be shown in cell 3, and that can sometimes mess up the menu-design..
    Everybody with me so far??
    So, I solved this my NOT padding the .menu .mi class - which of course made the menu text appear directly along the left side og my menu - not nice.
    Instead I padded the .menu .m .txt class....
    Problem solved
    Now, about the seperator...., well I just added the seprator graphics to the bottom image and fixed the other seperator images by using the .menu tr.mi class...
    Another problem solved....
    I hope everyone understands this, since it's the best explanation I can come up with.
    But I have to mention that:
    1) I am used to style the SolpartMenu, and have never used the Provider system
    2) The namespace/class styling of the NavigationProvider is a hell of a lot easier than the "Old School" styling, and I would never have figured it out, if it hadn't been for issue 52
    You can se the preliminary design at dev.hifi4all.dk - issues with Browsers other than IE - the top Menu item doesn't show correctly (even though it did on one of my develpment PC's)...
    That design calls for a First and Last menu item that's styled differently than the middle menu items...
    I'll post my entire Menu stylesheet, if anyone want's to see it....
    Regards,
    Martin Moesby
    2011-01-25 02:29 PM
    Thanks for the explanation!
    Page 1 of 212 > >>
    RE: Deploying dnn by Sameer
    Just sent it.
