FTP website using DNN
Last Post 2010-01-06 07:22 PM by stoyan. 6 Replies.
stoyanUser is Offline
2010-01-04 03:35 PM
Hi everybody and Happy New Year,
I searched the forum but I did not find the answer.
I use one of my DNN websites as a client web portal. Basically, I upload large files, create an user name and password, and then my "clients" log-in and download their files. I've been using this for about a year and it works great.
Now, I need to make it work the same way but for my "clients" - they log-in, upload their files and I download them. I need to do this but, I don't want them to have full access. I don't want them to be able to change anything to the portal-just to upload their files.
Any ideas?
Thank you
Stoyan Dimitrov
2010-01-05 05:39 PM
If you look around, particularly on Snowcovered, you will find modules that allow you to create upload facilities. The Repository module also permits this. I think also that Michael Washington has a free module that permits large file uploads (see Silverlight Bridge at adefwebserver.com).
2010-01-05 09:50 PM
Thank you Joseph,
I am looking at the options now but as much as I know the repository module is limited to size. Correct me if I am wrong but isn't something like 8mb? And I need it for size 25mb and up, something that will not go thru our emails
2010-01-05 09:56 PM
You can change the maximum file upload size by editing web.config. The Silverlight module that I mentioned doesn't have that restriction (That is what I recall, but you should check it out).
2010-01-06 06:58 PM
I just installed silverlight bridge and all of my websites are down great
2010-01-06 07:12 PM
Yikes.  What kine of error message are you receiving? Do you have ASP.NET 3.5 SP1?
2010-01-06 07:22 PM
fixed it but definitely the problem came from silverlight bridge...I can't get you a print screen but it was giving me some error messages and it was saying that it can't load silverlight. I didn't have any problems verifying and installing it As soon as I installed it, the websites went down...I'm going to try couple other things and we'll see.
Stoyan
