Store Module - Customize Billing & Shipping Address
Last Post 2010-01-05 05:48 PM by Joseph Craig. 1 Replies.
CBOSS INCUser is Offline
2010-01-04 03:10 PM
Using the DNN store module is there anyway to change the "region" label to "state"? Is there a way to remove the country drop down or just have United States selected as default?
2010-01-05 05:48 PM
If the module localizes correctly or uses the site's localization, you should be able to do this by editing the appropriate resource with the Language Editor. If you need detailed directions, ask on the module's forum at dotnetnuke.com. Unfortunately I'm not familiar with the Store module.
